show snmpv3 target-params
show snmpv3 target-params {[[hex hex_target_params] | target_params]}
Description
Displays the information about the options associated with the parameter name.
Syntax Description
hex_target_params Specifies the parameter to display. The value is to be supplied as a colon separated string of hex octets.
target_params Specifies the parameter name to display. The value is to be supplied in ASCII format.
Default
N/A.
Usage Guidelines
Use this command to display entries from the SNMPv3 snmpTargetParamsTable. This table specifies the message processing model, security level, security model, and the storage parameters for messages to any target addresses associated with a particular parameter name.
If no parameter name is specified, all the entries are displayed.
The following command displays the target parameter entry named P1:
show snmpv3 target-params P1
The following is sample output from this command:
Target Params Name      : p1
MP Model                : snmpv2c
Security Model          : snmpv2c
User Name               : testuser
Security Level          : No-Authentication No-Privacy
Storage Type            : NonVolatile
Row Status              : Active
The hex_target_params parameter was added in ExtremeXOS 11.0.
Platform Availability
